Right now there is no engine or transmission in it, but the rear end and driveshaft is in, waiting for a engine/tranny/tcase. I have driven this car everywhere, ive put well over 20,000 miles on it as an awd car and loved every minute of it. If I wasn’t getting another spyder to convert – I wouldn’t even be thinking about selling this.
I Have no problem getting this car running if you get me all the stuff it needs
Here’s what the car is:
98 Red Spyder GS Auto converted to AWD with a 96 parts car (no parts car comes with – its not needed)
Factory NON ABS CAR!
Cruise control is still wired in, just need pump and stuff for it to work.
Has faded and cracked CF hood - would be good painted factory red
Clean title (cheaper insurance since its titled as a GS
All wiring, Welding, and cutting has been done. Just needs engine and tranny.
Has single piston GST calipers up front. I can put on gsx dual pistons for a price though…
Stock GSX suspension
Sway bars front and rear
will come on stock swirly rims
Car right now is wired for an evo 8 ecu, and speed density but to switch back to MAF would be a 1 wire solder job.
2 step works and i wired the clutch in for NLTS to evo ecu.
5 speed swap. only problem is reverse lights dont work, but i never really needed them or cared…but if you want i can wire in the manual reverse switch to make em work.
Brake lines replaced all around with rubber lines
STM master > slave clutch line
Heres what will be needed to get the car driving on the street:
Engine with all sensors
Transmission
Flywheel
Clutch/pp
Slave cyl
Axles
Transfer case.
Exhaust
Windshield (ive driven it everywhere with whats in it, but unless you know someone it wont pass inspection)
Evo 8 ECU, or i have a stock gsx ecu i could wire in.
Everything else is there and ready to go. I have a TON of extra parts too, so if you want to pick the car up with a head, block, and have them built and swap in your tranny that would work as well. I just don’t have time (or money) right now to do this and the others.
Heres pics, threads, and videos of everything I have on the car (online). All work was done by me as well, and if you have any problems or questions I will be more than willing to help you out or solve them for you!
http://www.mitsu-media.com/showthread.php?t=11367 < Build Thread
http://www.youtube.com/watch?v=UPDkmjf1Qyw < drag video
http://www.youtube.com/watch?v=mjUyrmzAuoM <drag video 2 – I won!
http://www.youtube.com/watch?v=kUIBRgiMZIw < driving in the hills down in Arkansas
http://www.youtube.com/watch?v=2jrcF294nOY < video of rust, and when the engine spun the balance shaft bearing
http://www.youtube.com/watch?v=d7VBnzSdtX0 < Video of the HX35 on the car. This was the 3r d trip to Arkansas with this car.
http://s824.photobucket.com/albums/zz170/hortanica/GSX%20Spyder/?action=view¤t=2011-04-22_18-45-18_475.mp4 < Friend revving it (Next to white spyder im picking up from the south) video
http://s824.photobucket.com/albums/zz170/hortanica/GSX%20Spyder/ < build photo album
Make me offers on it. It needs a lot of body work, but for an awd spyder - the hard work is already done! Also open to trades…
