so that’s the question, which is it?
not 100% sure but i believe pressed, only bearings ive ever done that were nciely bolted in were on an ecotech cavy and sunfire, got a pic of the bearing? if it has slots for bolts it might just be bolted in which is fucking easy =)
I did a pre ecotec sunfire and an alero, both easy bolt in setups.
I could check it out but I figured I would ask because if it is pressed in I will just take it right to my mechanic.
I should just google it, haha.
sold in a hub so i would say “bolted”
Looks like it’s pressed
http://www.letmegooglethatforyou.com/?q=98+Taurus+wheel+bearing%3A+pressed%3F
I’m gonna agree with 4door
http://www.ford-forums.com/ford-taurus/21843-wheel-bearing.html
looks to be bolted in.
edit: I keep reading, and I’m confused. I keep reading what seems to be conflicting info, but I’m no Ford guy.
Someone else chime in.
well now i dont know
LETS GO WITH BOTH
http://www.ford-forums.com/ford-taurus/8019-how-change-wheel-bearings-1997-taurus.html
link for a 97^^
bolted in 15mm
