Picked up my elect. water temp gauge. I searched a buncha other forums
on how to hook this thing up.
I’m gonna conclude that there’s a signal wire near the TB that’s used for
the on-dash water temp. gauge. I would basically tap into this wire
for my autometer gauge, right?
As Phil describes it on this pic:
The sensors are located on the front of the mani near the coolant outlet (center of pic). The single wire sensor is used for the gauge. The red plug is the coolant temp sensor for the ECU.
ya thats an ok price
for the oil gauge you will need this as well.
1/8bspt – 1/8npt Part# 2269 Autometer for oil pressure sender $24.13 with tax at PI.
Can I get part # for the required T-adapter: T for what? if you mean to keep your oil light and have the pressure gauge then you going to have to get a different part then i sugested. i just left the oil light out casue i can always look at the gauge.
Ok, I talked to the dude who sold my gauge and he said the gauge didn’t
come with the sending unit. And that he just hooked up the sending wire
from gauge directly to the thermostat on his engine.
Is the sending unit mandatory or can I just tap into the wire that’s hooked
up to the stock unit? I mean, all the sending unit is doing is converting the
temperature to an electrical signal.
