CREDIT: Davison Design & Development, Inc. and Whiteside Manufacturing Company, Inc.
To provide a buttressed competitive stance for this leading creeper manufacturer, the design team was asked to explore ways to reinvent the traditional mechanic's creeper; create a fresh, innovative identity; and facilitate a regain of market share. The Hover Creeper takes advantage of the air compressors found in most professional and do-it-yourself garages. Rather than maneuvering using wheels, bladders filled with air from the compressor "hover" the mechanic in place under the vehicle. As little as 40 PSI will lift a 300-pound person. Without wheels, the creeper will no longer get caught in cracks or on floor debris. Once in place, the mechanic simply turns off the unit to lower to the ground for added leverage while working. In addition, air-powered tools can be attached directly to built-in air valves on either side of the creeper.
at first I was skeptical about needing an air line but there are built in air valves on both sides of the creeper
and you realize that a spray gun can overload a small compressor right?
i know this think has to use more air then a inpact … so the question still stands … how big does the compressor / tank have to be to use the creeper ?
and after it get filled with grease and punctured by the small debris it hovers over then settles down on also? not to mention the drain grates under a good portion of work areas. not a bad idea but i think cost will scare everyone away from effectiveness
Definitely not true. If it worked well enough, I guarantee we’d have one at my dad’s place and since actual work gets done there, it’s dirty as hell. Semi trucks are not a sterile endeavor.
