air fuel guage hookup
Ive searched for about an hour. anybody know how to hook up a air fuel guage wires to a ka which wire connects where thiers like 5 ends of wires and i dont no where they go any help would be much appreciated
5 wires?
There should be 3, IIRC.
Red - +12V
Black - Ground
Purple - O2 Signal To ECU
yeah thiers those 3 then 2 thicker red and black wires that go to an inverter and out the other end what does that hook up to ?
the other 2 are for the light inside. hook those up to you ilumination
mike
alright thanks for the replys
one more question were is the o2 sensor located?
im a noob
Should plug into your exhaust flow…so just follow your exhaust manifold down until you see it tapped in (wires protruding).
Don’t just splice the wire in your engine bay, thats ghetto. Find the corresponding signal input to your ECU and wire it near there. You can find this in the FSM wiring schematic.
kay arsen what year is your 240
alright im ready to go thanks
"95 240sx
Don’t just splice the wire in your engine bay, thats ghetto. Find the corresponding signal input to your ECU and wire it near there. You can find this in the FSM wiring schematic.[/quote]
so i should wire it near the ecu under the right passenger side
alright
