how is it possible to not run an airflow meter??
That is a Sexy ride lol
Holy moly is that a VG30DETT?
ya vg30dett in a 240sx
back to the question guys!
Map or Blow thru setup.
Second question, can a maf metered engine be converted to a map or blow thru setup??
can anyone elaborate on this?
Most stand alones don’t use MAF’s. Like an SDS, you just tell it what it wants to read.
Yeah, with map sensor you will need the appropriate computer to be able to function with map sensor. All a blow through set up is, is that you run the maf after the turbo (use it as part of the intercooler piping).
perfect elaboration chris.
On a side note a friend of mine did that swap and said they suck ass. Said it was a waist of his time and a RB26 is a much better solution!
They often do it on GTR’s as Apexi has a power FC line called the “D Jetro” which uses a map system.
its affordable and easy if you own a gtr :lol:
They also have that for many other applications of the PowerFC. And i believe it uses a MAP sensor instead of the MAF.
They also have that for many other applications of the PowerFC. And i believe it uses a MAP sensor instead of the MAF.[/quote]
correct^^ the map sensor is actaully plumbed into the intake mani!
