AMS High Capacity Oil Cooler Kit Teaser!
AMS INC. is proud to release our High Capacity Oil Cooler Kit for the Z32. With our hectic tour schedule we had to push back some anouncements! Finally catching up :slight_smile:
http://amszstore.com/main/product_info.php?products_id=239
• The AMS Oil Cooler will deliver much higher volume compared to the tiny OEM variant! (OEM Z32 oil cooler)
• Cooler running motors perform more efficiently and last longer, likewise with the turbos! Compatible with OEM to wild builds!
• Kit is complete with AMS High Capacity oil cooler, mounting plate (Z32), bolts/nuts, A/N fittings and adapters pictured!
• Stealth Black finish!
• AMS laser-etched logos
• OEM Mounting spot for the Z32’s! (Bracket can be modified for other applications)
Thanks
Kevin@AMS
are -6 fittings really enough for flow?
i always thought that for oil systems youd want at least -8
These are designed for the 300ZX so the fittings are sized to fit oem and silicone aftermarket oil cooler lines that mate up to the same size fittings on the oilpan and oil filter housing.
I’ve run this oil cooler on my personal Z32 for the entire 2009 season and I’m more than slightly rough on it. This is a much larger upgrade over the oem z32 oil cooler or for a car which has no oil cooler to begin with.
i didnt realise that z32s came with stock coolers. that pretty gangster.
what kind of price are these kits going to be sold for?
About 195 for this kit, I’ll look into whether we will be doing any intro pricing. I can get back to you on that.
but yes as for the z32 oem coolers (just some low quality pics)
comparison to my prototype oil cooler oem is about half the size in height but also a thinner core.
Mine obviously isnt using the bracket which mounts them in the centre stock location in front of the ac condenser. I have mine moved over to the side where the stock sidemounts were. To show there are some options obviously with placement based on preference or individual setups.
