Since the Camaro is going to be a couple year project ever since we decided to cut it all up. I purchased this and then remembered that carburetors suck…
I decided to switch it over to Holley Dominator EFI it should simplify a lot of things since the car had a carb/ignition box/AMS1000 boost controller/data logger all separate and I can do everything inside of Holley.
Edit: huge thanks to Muscle Car Alley, Gary(I guess he works on stuff besides DSMs), and Vanstrom Performance for all the help getting all this together in a short period of time.
So I went and ordered all this crap
If anyone is interested its all this
Holley EFI Dominator ECU. P/N 554-114 1
Holley EFI Main Power Harness. 558-308 1
Holley EFI Universal MPFI (Multi Port Fuel Injection) main engine 558-104 1
GM LS Sub harness’s Depending on coil type. 558-307 1
Holley EFI COP Sub Harness. Connections for Holley Smart Coils. 558-312 1
Holley EFI Universal Ignition Harness. 558-306 1
Holley EFI Ford EV1 Injector harness. 558-209 1
Holley EFI J2A Input harness. Pre-terminated for second wideband O2. 1
Holley EFI NTK Wideband O2 Sensor 554-100 2
Holley EFI 5 Bar MAP Sensor. 554-108 1
Holley EFI Coolant Temp Sensor. 534-10 1
Holley EFI Air Temperature Sensor. 534-20 1
Holley EFI HI-Performance C-N-P SMART COIL 556-112 8
Holley EFI J1A/B Input/Output Auxiliary Harness. 4 Inputs/4 Outputs. 558-400
Holley EFI Boost Control Solenoid. 557-200 2
Holley EFI Stainless Steel 100psi transducer. 554-102 1
Holley EFI 160 LB/HR PERFORMANCE FUEL INJECTORS - SET OF 8 522-168 1
Holley 554-118 Hall Effect Crank Pickup
Then we stripped all the wiring in the car
Then bought some more stuff
- Updated - - -
Had to change out the intake manifold/fuel pressure regulator for EFI
The hotside all got wrapped and the turbos are getting turbo blankets
[img]http://i.imgur.com/vBvVDUL.jpg/img]
Throttle body got vbanded
- Updated - - -
New steering shaft
Strange master
Coil brackets
Family member was night enough to shoot me a whole box of racing gear
We are getting pretty close to firing it up waiting on a few things to ship including bottle bracket for the CO2, push lock fittings for the wastegates, brakes, and a few other small things
- Updated - - -
Original plan was to rewire the whole car with an aftermarket harness but the factory one was stripped and repaired. The car will can get a complete aftermarket body harness this winter when I switch it over to digital dash and change a few other things around.
New master installed leaving a lot more space
