Hey guys check out my BOVSS! Blow Off Valve Super Seal!
the idea is it goes between the factory mounting point (pic below is MR2) and then lets any type BOV go on top. It is a butterfly flap with an electronic actuator that snaps shut at anything above 4psi. The idea of this is that all BOV will leak at high pressure / high RPM driving, it has been proven to loose HP with this problem at the high end. So, the idea is that this will hold it sealed. Note: it is NOT a blow off valve. It is simply a seal to help the car from loosing boost pressure. The sensor would be operated after the throttle body as to see TB pressure, allowing the valve to proporly open/close
What are your guys thoughts? how much would you be willing to pay for this if it meant 5-10rwhp at top end?
Designed In Solidworks 2003:
