…That could bring a small dry cell odyssey type battery back to life? Barely got to use this thing and it went dead on me at some point. Now it wont take a charge with my trickle charger…
i have two
PMd
ya need a dry /gell cell charger thats why .standard ones will fry them if ya do
aah ok. So if i put a normal charger on it you think its done for?
Ive killed 2 PC680’s with chargers in the last few years, although never had issues with my Braille. Couldve been from a couple 60 amp jump charges though… :facepalm
odyssey’s, unfortunately, are junk. We had one in the bike swell up so bad from normal discharging during starting/cranking that I had to cut it out of the steel box it fit into with 1/8" factored clearance all around. They’re not a good battery for repeated cycling without good proper charging in between cycles.
If you can get it to hold a charge again I’d be surprised.
I’ve got one that does 12 batts at a time… any configuration up to 72v.
