I was wondering if anyone has the settings to run TT 300zx maf and 550cc injectors on a sr20
Codes??? :?
Sorry I meant settings
Nothing.
You dont need to do anything.
If anything add like 1% fuel across the board but thats it.
i think he means the numbers to set that mafs and injectors y0
the 550CC injectors will work correctly with the Z32 mafs for the most part, as the 550CC injectors and Z32 mafs are equally larger than stock,
however if you want to do it by inputting the MAFS into the S-AFC and tuning for injectors (will do the exact same thing)
check the s-afc book on apexi-usa.com for 300ZX twin turbo as your mafs IN and the Sr20 that you have (im assuming S13) as OUT
then take out 33% fuel across the board
