Audi Help: 2000 Audi A6 Avant 2.8L V6
thanks mike for help
Id assume the CEL is on?
You def need vagcom. Get it scanned with that first, then try to fig out whats going on.
Dan
Yes check engine light is on.
Im trying to source out someone with a VAG-Com lol
Ah, Id help but Im on the east side of Rochester.
Dan
sorry to hi jack but i need a vag com as well
m
http://www.034motorsport.com/fabrication-exhaust-plumbing-o2-sensor-spacer-for-bosch-style-sensors-p-18938.html?osCsid=jbtvsrs4u4i7iqnosps3aqnla0
get two of these for the rear sensors if the cat codes come back. I used to machine and make these out of HELP spark plug spacers for bosch sensors with my lathe but it’s not worth the effort anymore.
Are the p0421/0431 are they rear [after cat] o2 sensor? i havent been under the car to check to see if there is 2 cat or 1. i know the 2.7t has 2 lol but not familiar with 2.8l
very similar to the 2.7, two of them routed in the same place.
