Auto KA to Manual SR questions
Hey guys, I’m currently saving for an sr20det swap and I want to buy the extra parts that I will need from a Manual 240sx. I read the A/t to manual thread, heres the parts needed for that:
Clutch Pedal Assembly
Brake Pedal Assembly
Clutch Master Cylinder
Clutch Slave Cylinder
Clutch Hard & Fle Line
Manual Tranny
Manual Driveshaft
Manual Tranny Brace
Manual ECU
Lower Wiring Harness (M/T)
Interior Shifter Cover
Interior Pannel w/ Boot
Shift Knob
Can someone please tell me which are needed for A direct A/t Ka to Manual Sr swap
Thanks in advance.
anyone know?
Moved to technical.
That part of the swap will be very similar to the KA auto to KA manual swap … in which there are a bunch of threads in technical and how-to sections. The KA to SR swap is also in the technical and how-to threads.
goooOOOO!!! Search button!
EDIT: … wait you read those already? … then why are you asking this question? Swapping a auto KA to manual KA would be exactly the same as what you are doing, they are just transmissions, why would it be any different for an SR?
yea really its same same regardless of engine.
theres no real fundamental differences between the 2.
you have your info.
GT
