bad oil pump?
oil gauge started doing some weird stuff… reads low all the time after the engine warms up… but i just changed the oil and its full… and when i stop at a redlight or coast out of gear it shows no oil at all… wtf?
check sender first!
wheres that at ? will it fuck my engine if i let it go a day?
shoulndt…the sender just tells u your oil pressure…if u konw u have pressure than ur ok!!! but it would be nice to get it fixed as soon as possible!!
I wouldnt continue driving on it until it gets checked out…
my $.02
If it’s not the sender, it could be pump or worn bearings.
x2
I have replaced them on every damn car I ever had. They are like $10 and just screw into the block somewhere. It should only take about 15 minutes to change it, and that’s with 10 minutes looking for it.
sweet ill change it tomorrow!
