car: 1990 acura integra
motAr: B18…non vtec (there i said it).
oil light comes on. sometimes it fades in and out. gets real dim, then bright, then dim. sometimes it just stays lit up. sometimes it flashes. sometimes it doesn’t come on at all.
obviously, i check the oil. the first two times the light came on it was a few weeks apart. it was a little low so i added some. a few weeks later, the light started coming on intemittently, but almost everytime i drove the thing. i did the usual first response to a problem on my car and hoped it would go away.
it was time for an oil change anyway. i changed the oil. put in 4 quarts of 5W-30 and a new filter. light went away for about a day, and now it’s back. i check oil level, it’s fine. i’m assuming these warning lights are triggered by oil pressure. i took the cap off the valve cover while it was running, and i can see oil shooting up and about. i’m guessing the oil pump is working ok.
could it be a bad sensor?
