Basement build - starting with better rim joist insulation
I have approximatly 1,100 sq. ft. of unfinished basement. I am lucky that it is both dry and radon free. I use the majority of it for laundry and storage, and then the rest of it is my workout room. I am planning out finishing the walls over the next year or so, but I started with a basic, and smart project, insulating the rim joists. When I bought the house all of the rim joists had R-13 fiberglass insulation stuffed in, which is better than nothing, but not really ideal anymore. Here is what I am working with:
A shot of the workout room wall
https://farm4.staticflickr.com/3864/14611891212_22e1e35232_b.jpg
The old insulation
https://farm4.staticflickr.com/3875/14425811748_fb56ff84b7_b.jpg
Insulation removed
https://farm4.staticflickr.com/3910/14632417163_cda192a456_b.jpg
Look at the dark stains on the fiberglass, that is all from airflow coming through the rim joists into the house
https://farm3.staticflickr.com/2909/14425812038_f1461cc1b6_b.jpg
I cleaned up each opening, cut the 9.5 x 14.5 pieces of R-10, 2" thick rigid foam out for each one, and then used Great Stuff spray form to seal around the edges. The final result is an air-tight seal that will keep any outside air from entering the basement walls via the rim joists. I can now put in fiberglass insulation over these openings once I finish the walls. I will likely do R-13, but R-19 is another option.
https://farm4.staticflickr.com/3887/15181162285_4036c4685a_b.jpg
I did one wall so far, so 5 walls to go.
My future plans are 2" rigid foam on the exterior walls, followed up by a traditional 2x4 stud wall to run electrical and drywall. It will make the space approximately 6" smaller on each wall, but it should be a much cozier space. :tup:
Looks good, def use this as an example/inspiration.
Are you going to place the rigid foam on the wall, leave a gap, or use a vapor barrier?
Good stuff so far. I removed the R13 from my basement this summer, and haven’t replaced it yet. Did you use anything but the spray foam to hold the foam board in?
I have a very large basement project upcoming. And a kitchen, and two bathrooms, and… I will make a thread for it.
ANYHOW, What is he ceiling height in your basement?
Completing a basement project right now…i should make a thread
GL
Doing my rim joist as well, I am buying a 2 part spray foam that covers 600 linear feet. Air tight, easier then cutting foam. Did you look into that at all?
I only used the spray foam to hold in the board. I cut them to size within 1/8", so most of them I had to pound in to get into the space. The foam definitely tightened up the few that went in loose though. They are all solid and sturdy now.
I am going to put 2" rigid foam on the wall as well. I am not using a vapor barrier or leaving a gap. I am using this 2x4 wall method, sans the extra fiberglass insulation between the studs:
I can’t think of the measurement at the moment. It is less than 8’, but more than 7’. I can do jumping jacks down there when I work out, but I have to be careful to not hit my fingers.
I did, but this will do the same job, at way cheaper. I can do my entire basement for around $100 with this method. It is a ton of work cutting out all of the slightly different sizes though, and there are a few openings that have wiring, ducting, etc…, so if you have the money to spend, the spray foam is probably a way better option.
Looks great so far!!!
Cool shelf bro.
Dan
