Now that I have Wheels and tires…
Need to have wheels mounted and balanced tomorrow if possible after 5. Best suggestions for 18" wheels?
tirerack is hard to beat. what rim size? i can probobly get them all mounted and balanced for you for like $40 depending on the size.
If you want cheap, call tread city tire in NT. Big ass pole barn full of tires with a mounting/balancing machine. Extremely low overhead, as in the waiting room is an old couch outside the office room among all the tires.
[quote=“STEALTTH”"]
Need to buy tires…Where would you go? Why?
Also, once the tires come in I will need a place to mount and balance.
GO!:eekdance:
[/quote]
when i got my 4 kuhmo mx’s i think it was 4xx shipped from tirerack.
lol @ tirerack being hard to beat.
[quote=“Adictd2b00st,post:3,topic:31820"”]
[/quote]
Warning: mysql_pconnect(): Can’t connect to local MySQL server through socket ‘/var/lib/mysql/mysql.sock’ (111) in /home/web/www/index.php on line 27
Warning: mysql_select_db(): Can’t connect to local MySQL server through socket ‘/var/lib/mysql/mysql.sock’ (111) in /home/web/www/index.php on line 28
Warning: mysql_select_db(): A link to the server could not be established in /home/web/www/index.php on line 28
Warning: mysql_query(): Can’t connect to local MySQL server through socket ‘/var/lib/mysql/mysql.sock’ (111) in /home/web/www/index.php on line 94
Warning: mysql_query(): A link to the server could not be established in /home/web/www/index.php on line 94
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/web/www/index.php on line 95
Warning: mysql_query(): Can’t connect to local MySQL server through socket ‘/var/lib/mysql/mysql.sock’ (111) in /home/web/www/index.php on line 110
Warning: mysql_query(): A link to the server could not be established in /home/web/www/index.php on line 110
Warning: mysql_query(): Can’t connect to local MySQL server through socket ‘/var/lib/mysql/mysql.sock’ (111) in /home/web/www/index.php on line 111
Warning: mysql_query(): A link to the server could not be established in /home/web/www/index.php on line 111
Warning: mysql_result(): supplied argument is not a valid MySQL result resource in /home/web/www/index.php on line 112
Warning: mysql_query(): Can’t connect to local MySQL server through socket ‘/var/lib/mysql/mysql.sock’ (111) in /home/web/www/index.php on line 152
Warning: mysql_query(): A link to the server could not be established in /home/web/www/index.php on line 152
Warning: mysql_num_fields(): supplied argument is not a valid MySQL result resource in /home/web/www/index.php on line 153
:eekdance:
hey i don’t run the site :gotme: all i know is they have good prices, and its not coincidence that 3 other people have said the same
We can get you tires at a good price. What are you looking at? PM me the size and tire you were looking at, I’ll see what I can do for you.
Don
[quote=“Carnut,post:12,topic:31820"”]
Don
[/quote]
[quote=“JuicedGT,post:2,topic:31820"”]
[/quote]
255/35/18 Rears
225/40/18 Front
[quote=“Locutus,post:7,topic:31820"”]
[/quote]
I swore off kuhmo’s a little while back…how do you like em on the stooooook?
[quote=“BikerFry,post:6,topic:31820"”]
[/quote]
TCT is by far the best… cheeper then tire rack and the will come to our work and do it for you …ill pm you the # when i get home
[quote=“justa4door,post:14,topic:31820"”]
[/quote]
sweet :tup:
If they have a website i’d take that too ![]()
[quote=“STEALTTH,post:16,topic:31820"”]
sweet :tup:
[/quote]
no i dont …im also here sitting at a desk … your right in not doing anything … ill search
all i got right now
Tread City Tire Incorporated
89 Thompson St
North Tonawanda, NY 14120 Map
(716) 693-4800
[quote=“STEALTTH,post:13,topic:31820"”]
[/quote]
They are good… a little slippage when i take u turns at 35 but a little counter steer fixes that ![]()
cant find a website :gotme:
