best place to get pads and rotors...TODAY
In need of pads and rotors for my brother in laws TL-S.
Where a good place to get them for a good price. Last time I got rotors at pepboys they were jacked
Napa. Always had good luck with their brake components, especially their blank rotors.
Napa +1
go to the napa on wehrle… its the main buffalo warehouse and most stuff is in stock there that wouldnt be in teh other stores
+1 for napa.
my last rotors were from napa. they sucked so bad. after about 6 months of driving they were VERY warped. i would brake and the whole front end and wheel would shake… went to Advance picked up a new set and they have been good ever since
That shaking is more likely to be brake pad deposits than actual warping…Warped rotors are somewhat of a myth. 90% of the time, when someone says their rotors are “warped”, they just end up having a lot of brake pad deposits left on the rotor. As those deposits build up, you will feel the car shake when braking, as if the rotors were warped. Go get them cut, then replace the pads with something decent.
well iv had the new rotors on there for almost a year with the same pads that were bought from napa with the origional rotors. and not a single problem
^^^you can also get the shake from vibrations of the pad against the rotor. putting grease between the caliper piston and pad as well as grinding a 45* on the leading edge of the pad if it dosent already have it will fix this. rotors 99% of the time will not warp unless they are turned down thinner then the reccommended measurments.
