I had a bad crankshaft position sensor, which I replaced. Once I replaced it, the vehicle went crazy about a day later. Here’s the symptoms: Brake, 4x4, and automatic transmission warning light all stay illuminated. The vehicle bucks and jerks, searches for gears as the RPM’s bounce all over. The battery light will flash when the RPM’s bounce. It has a new alternator and the battery is at 88% charged after being tested.
Here’s the codes I had pulled:
ECM:
2718 Crankshaft sensor: reference mark
3CD1 Crankshaft sensor: signal
279C Thermostat, map cooling: activation
DSC:
5EB1 Steering angle sensor, supply
5F21 Engine management interface
5F41 Transmission control, limp-home operation
Gearbox Control Module:
54C6 oil wear
55C4 No message from DSC
55C5 No message from engine management
Central Body Module: total codes 11
4C passenger mirror internal error: timer watchdog
0D Power window open circuit jam protection strip lost or caling error EKS electronic driver’s door
0E Power window open circuit jam protection strip lost or caling error EKS electronic passenger door
0F Power window open circuit jam protection strip lost or caling error EKS electronic driver’s door behind
10 Power window open circuit jam protection strip lost or caling error EKS electronic passenger side behind
6B no answer passenger mirror
6A no answer switch block
6C no answer drivers mirror
33 wiper: is blocking or reset contact
5F driver mirror: potentiometer axel 2/4
3A Wiper: replay pump or wire for headlight cleaning system
I looked at the plastic gear in the transfer case actuator, it was fine, no wear or missing teeth whatsoever. At this point I’m thinking something is shorted out. I’m at a total loss on this one. Any help would be appreciated. 2004 BMW X3 2.5i
