Audi ABS wheel speed sensor Q (b5)
http://www.audiworld.com/tech/wheel45.shtml
Backstory… Wayne and I just did the wheel bearing of my B5 A4 today. Unlike the above tech article the wheel speed sensor did not have a 5mm bolt holding it in place, it seems it is pressed in with no bolt. After fussing with it for a bit, we decided to leave the sensor on the knuckle and disconnect the clip from under the rear seat.
Most likely we marred the face of the sensor when messing with it, as my ABS and brake light are now on in the dash.
Simple question… is my brake light supposed to flash when an ABS sensor is bad? Everything seems perfectly fine on the car in terms of braking, although I have yet to apply enough brakes to induce skidding. That flashing brake light on my dash is annoying, just making sure I shouldn’t recheck my parking brake cable or something stupid.
Thanks again to Wayne for his help… and no worries on the ABS sensor… that fucker needs replacing anyways!
GermanPSI has this same problem with the disco lights on the dash with his b5 a4 also. Im sure he will chime in.
yeah that was a long OP…
basically I want to know if the flashing brake light AND the abs light come on when the sensor goes bad… or should I be looking deeper into this.
Peace of mind I guess…
… that stubborn sensor is gonna get replaced soon.
Abs module is bad. Sounds very weird though to have it happen after u messed with it. But if u broke the sensor only the abs light would be on
ps… Waynes the man! I prolly would’ve ended up cutting the damn sensor cable off if it wasn’t for him!
THE fuck?
details?
When you have the abs light on and the brake light flashing this means your abs module is bad. If the sensor in the back where you did the wheel bearing was bad it would just throw an abs light and not a blinking brake light also.
Yeah, I did some research on it last night. Not too excited about it, but I should be able to have it rebuilt by any number of companies for pretty cheap.
The thing that has me very confused is why it went at the SAME time we did the right rear wheel bearing and sensor. It just seems really odd that it happened at the same time.
Lastly, based on what I’ve read I will be just fine without repairing the module, I just won’t have ABS. Can you confirm this? Any long-term negative effects from letting this simmer for a while? (with the exception of that ANNOYING flashing light that is)
Doesn’t make sense it’s throwing a code for a bad ABS module. If I were you I would disconnect battery, pull back seat, and recheck that connection where we unplugged it. check to make sure maybe the wires didn’t get half pulled out of the connector while it was swinging around in the press etc. either way at least unplug it and check the connection under the seat there. That’s the only thing we touched, maybe its somethign super simple. Doesn’t make sense the module is bad all of a sudden.
Anyway when your done plug the battery back in and fire it up, see what happens. I know you mentioned you were having some electrical gremlins anyway. Just seems funny to me after all we touched was that harness that you get a bad module.
Yeah Chris has had those lights on in his a4 for a year and a half. no biggie. I think he is going to do the same thing as far as sending out the abs module to get fixed.
Yeh I’m just saying that when the brake light blinks and and light is on the abs module is bad but do agree with Wayne that’s it’s really strange that it happened right after you did the wheel bearing. Doesn’t really make sense
def bro, not disagreeing with you on the light meaning the module’s bad, just saying it don’t make sense. I’d dick with the connections we touched again before ordering a module.
But then again you could leave that sensor unpluggged and it should only thow an abs light not a blinking brake light
hmmmmmmmmmm that not a bad idea either…!!
orrrrrrrrrrrrr take it somewhere and have the system scanned
If the sensor is grounding out it could be making the light blink.
what is geounding mean ? i have heard of grounding out and what not .but the fuse could be tripped a pad sensor could be tripped and so on
Lol. I’m on my phone at work. Fuckin small buttons FTL.
this didn’t have pad sensors in the rear.
ok , if the sensor is shorted it may pose the same problems though
