boost gauge install help
im going to be installing my boost gauge this weekend and im not too sure which line i need to T off. i have an HKS BOV, everything else is stock. also wondering as well, where can i find the line that is used. i dont have enough. thanks
Click on the link i posted in the sticky
http://www.n-e-c-c.com/forum/viewtopic.php?t=923&start=30
Then go to info then vacuum line
That link in your link is dead
Throttle Body:
The throttle body has 3 vaccum sources coming off of it. Two above the throttle plate, and one below. The top left vaccum source is for the fuel pressure regulator. Also, if running a boost gauge (like you should), you will need to T off of this source to get the boost gauge signal. The top right vaccum source is for the Recirculating or Atmospheric Blow Off Valve. Lastly, the bottom left vaccum source is for the carbon canister. However, a lot of SR swaps will have this capped off because not having it isn’t going to make us fail emissions. We fail anyways! The large hose above the throttle body that connects to the intercooler cold pipe is for the idle. Please hook it up; your SR will thank you.
hmmm doesn’t look so dead to me.
http://www.sillbeer.com/info.php
Works fine for me. Except the home page got changed.
