CA Rebuild Kits
Where can I buy a kit to rebuild my engine? Something that comes with all gaskets, new bearings, rings etc. I’m doing it this January so I figured I would start looking now.
Do u want aftermarket stuff? cause nissan or other part places should be able to get u oem type stuff. Just for a CA18DE, i dont know if there are differnet rings or head gasket in the DET, Rob parson mihgt know maybe shoot him a pm.
you can use allmost every part from the ca18de to get your rebuild going! i have a full set of .25 over main and rod bearings if your crank needs work…you can use DE rings if i recall… and the DE headgasket is the same…get after market pistons cuz the stock ones blow balls! a good investment when you have ripped it apart! make sure you keep your lifters in oil or else you will have a damn noise engine! look at www.nicoclub.com for allot of part numbers and stuff…look under the CA section
