As you can see from the pictures the disk is completely toast and everything is burned to shit so i have no idea what to do, JUST so you guys know i don’t have $900 to buy a rebuild kit or the $1000+ for a new OS giken
So if any one knows where i can pick up a Stock flywheel for cheap or a part number i could go to nissan with to get a new one that would be SOOO helpful
Also would it be possible to just get a replacement clutch disk or is the whole kit in bad enough shape its not worth it ??
Lots of info on NICO for ca18 owners. Lots of guys on there are running SPEC clutchs, because they make about 8 stages of clutchs for the CA, so you can buy whatever strength you need. But all the info is there, just search around a bit.
I think you can use the KA clutch, either as-is or swapping out a ka tranny using the ca bellhousing. I’m thinking of using the KA tranny with the CA due to the ka having a longer 5th, the ka is bad enough at highways cant imagine how a shorter 5th 'll be like buzzing on the highway at 4krpms+.
Yeah ive looked into that too, but i have a CA Diff so it will even out. also i have a ka clutch but you need a CA flywheel which i currently don’t have.
