CA18DET Questions
Ive got a 90 180 with the CA and im not sure about a few things so im here asking if someone with far supirior know how can answer my questions.
ive got the CA brakes and i bought the specific pads for them off another member. (Grex Pads) now can i use normal 240sx rotors or am i gonna have to order specific rotors too? same with lines?? i want to do my brakes this weekend and i wanna get slotted rotors and stainless lines. also are the rears the same as the 240sx brake set up???
Spark plugs. i was told by a shop that sr20 plugs (NGK) are the same for the CA. is this right ?? if not can you recommend some part numbers or a brand. thanks
Thanks for the help
Brad
Youll need 180sx rotors, 240 ones are bigger. But the lines are the same And the back brakes are the same on all S13’s. As for spark plugs just look for a 89 pulsar with the 1.8L in it(CA18DE) and i believe you want a heat range of 6. and ya I think they are the same for an SR
There ya go, more info on that site then you can read in one day
