Question about CA brakes...
Would KA24 brakes interchangable to a CA18 ?!?!
my rears started squeeking i am just wondering if i can just throw on a KA24 set for a little cheaper ? or should i just go aftermarket ?!
thanks…
What part of the brakes? Calipers or Rotors or Pads?
pads …
also what is the sr20 brake system ?
altima rotors and maxima pads ?!
90-95 Maxima calipers and pads
94 Altima rotors.
They are 11 inch instead of 9.5 like ca and ka brakes. The rears are the same for all s13s.
Hey, your rear brakes are the same as the north american 240’s, only the fronts differed from USDM/JDM. CA18 cars have a front brake setup unique to japanese S13’s, and no car in north america came equipped with the same ones. The 240’s brakes are so similar its hard to tell them apart, but trust me…the pads have a different notch pattern and the rotors will rub on your caliper brackets.
Later 180sx’s came with the altima/maxima combo, I am unsure if they started using this combo when the SR20’s came out or if it’s the kouki 180sx’s that adopted them, but if you can find a set of them on ebay pick them up because they are great brakes.
I swapped my whole front setup to USDM just for the ease and because the CA18 pads/rotors are a pain to get, but the USDM set I got is shot so I went ahead and ordered Z32 TT 4 pistons, they arrive tommorow and I think your best bet is to just bite the bullet and upgrade your brakes because pissing around with the CA brakes is a waste of time.
If its only your rears then you dont have to worry, just pick up a set of 240sx pads/rotors and slap em on.
dont forget about the USDM ABS brakes they r also larger dia. 10.3" or so…forget…but 240sx ABS pads do fit into sr20 calipers…i put them in my old 180sx
thnx guys
