can nebody help
my 92 vr6 corrado finally got the motor back 2gether when i got to start it only thing it does is the pulleys more the plugs are getting fuel i know its somewhere in the ignition put in a new distributor and coil back still no luck does andbody know what it could be
I can help you out. It’s ANYbody not nebody. :rolleyes:
check timing?
hate to say it but its a VR6 corrado… possibilitys are endless.
coil pack gone bad? ECU gone bad? good lick
what does that mean?
SIT DOWN, REPHRASE, AND RETYPE… as what u wrote made no sense…
ok, was the car running b4 u took it apart? what all was changed? and what is it doing now?
ok sorry going to retype it when i would turn the ignition the only thing it would do is spin the pulleys i know that fuel is getting to the engine …found out 2day that whoever had it before me cut the coil harness and rewired it but it was rewired backwards causing me to blow 2 coils so hopefully when i find one it will now work …does anybody have one used? also looking for any other parts
nope sorry:(
for coil, we have one at maroney’s, 45 bucks. same as a passat vr6. other parts, dont have anything aftermarket. should have oem parts.
and sorry aboput caps earlier, as computer at work is in caps lock mode
oh yeah, maroneys is open m-f from 9-6, saturday from 9-1. number is 1800 245 7278, or 724 872 6316
