So i got my gsr running again. it runs and drives fine till it is done with open loop. Then it runs like crap cutting out real bad under boost. The cel is saying its my iacv. Is it worth taking off and cleaning or should i just get another one? Is it a poss that thats not even the prob? It never did any of this before my icm and coil shit the bed. let me know thanks.
Do you have the connectors mixed up? Some of the plugs are the same.
everything is just like it should… I triple checked averything again.
easy iacv test… 12v and ground on either side. it will click and move one direction. reverse the terminals and it moves the other direction.
if you at one point switched the iacv and iat pigtails you will fry both sensors…it just happened to me last winter. They will fit both
I was just about to say that. They get different voltages…
oh snap, baldy beat ya to it ![]()
There is a first for everything I guess :cuddle:
If Ford Motor Company is FoMoCo,
what does that make Honda?
HoMoCo.
It’s funny because it’s true.
who went bankrupt this year…I think it was a company called GM??? :bigok:
i threw the same code once…took my IACV off… and found a pebble stuck in it… no idea how it got there… removed it and been working fine ever since
a pebble? good thing it got caught there!
ok so how much is the little piston inside move?
first darkstar thats halarious
second GM didnt go backrupt if anything chrysler went backrupt
third he didnt say anything about GM he was talking about ford
It’s not hilarious. It was really stupid.
Yes, GM did go bankrupt.
They all know I own a C5 Corvette, hence the GM reference.
:rolleyes:…thanks for clearing things up!
