My boss has a 02 or 03 GTP, honestly I have no clue.
Well he’s had a remote starter on it for almost 2 years now, and last month he had a new battery and alternator put it.
Now when he goes to use his remote starter, the car starts and then shuts off after 2-3 seconds. Then it starts back up and then dies. And continues the process of starting back up, running for a second and then dying.
When he starts the car manually (key in ignition) the car starts, runs and drives fine. Its just that the starter isn’t keeping the car started.
Any ideas? I’m thinking bad ground, or its shorting out somewhere.
This is a remote starter problem, correct? And not an electrical problem that lies within the grand prix?
he probably got some POS remote starter installed for 80 bucks on special from circuit city. If the car starts and runs with the key in inigtion, just get a new remote starter.
that said, remote starters are for fucking pussies.
You dont have to buy a new remote starter, or bypass module like stated above. Removing the battery in a car will delete the memory in the remote starter and/or the security bypass modules on some systems, it depends what products were use.
Is the security light coming on in the instrument cluster? If thats the case, then the PK3 bypass needs to be relearned (assuming its not a key in the box bypass).
If thats not the case, the engine sensing needs to be re-programed…be it voltage sense or tach sensing. The car wont start correctly if it doesnt have anything to monitor.
