Copying my post from another forum…
So a couple of days ago, I’m idling the car first thing in the morning and I notice the RPM’s falling to around 500 and back up to 600. Car is almost stalling but catching itself.
Today, I’m driving home from being out and if I give the car 10-20% throttle (I’m guesstimating)…the car bucks and otherwise doesn’t want to accelerate. If I let off the gas, car coasts perfectly fine. If I give half throttle or more, car moves like it should. Why is it only ‘catching’ in that particular lower throttle range?
I have had a P0171 code for the last 11 months…been trying to fix and haven’t had much luck. However, when I scanned the car just now with my scanner, I got:
P1105 - Generic - Pending
P1105 - Generic
P1105 - Generic - MAP/Baro Circuit Malfunction
My P0171 code was nowhere to be found. Light (CEL) was actually off earlier in the week. Perhaps it solved itself?
I also noticed a funky smell as the car was ‘sputtering’ at idle (I’m outside). It’s not gas, it’s not oil, it almost smells like what the PCV valve does when you pull it out.
I have a spare (my stock) MAP/Baro sensor (located on the intake snorkle) that I’ll try replacing but is what I am experiencing a symptom of that sensor being bad? It almost felt like the MAF (when the MAF is bad it won’t let you go past 3k rpm) or possibly the TPS.
Later on…
Well I changed the MAP/BARO sensor to another one I had (that should be 100% functional) and the issue is still there.
Here is a small clip of my problem:
http://www.anyyouth.com/other/CarProblem.wmv
Car has issues if I’m anything less than 50% throttle.
Could it be my fuel pump/relay/filter?
Maybe I just got a bad batch of gas? Isn’t there some kind of chemical you can pour into the gas tank if the gas is ‘bad’? Dry gas?
