Hello, Dont know if this is the right place to post, or if anybody can help but I could really use some help on installing a stereo system . Im wiring a line out converter off of the 2 rear speakers. My problem is I wish to use a stand alone battery in the trunk, apposed to off the car’s battery. I have a diagram of what im planning on doing.
Couple Questions:
- is there a need to wire the negative terminal on the battery(ground it)?
- using the stock Head unit will my jerry rigged remote wire with an on/off switch work in the same fashion as if i wired it directly to an accessory fuse or just wired it into the stock head unit remote wire?
Any other help or tips is much appreciated!
Link to diagram V
