I’m wiring up a 2nd battery in my truck just to power the 12v toys but wanted to double check my thinking on the matter. My primary battery is in the stock location wired up how GM did it in 96 but with all 4 gauge wire. I plan to connect the 2nd battery in the bed with 4 gauge. I don’t think it matters - but should I make the front connection on the +positive side of the battery or on the alternator? Directly from this connection I will have a 100a circuit breaker that will go into a 100 amp relay in my cab. I will actuate this relay with the ignition. After the relay I will have another run that goes directly to the 2nd battery +positive terminal to charge it while the truck is running but will also have another 100 amp circuit breaker to go my 12v toys with another 100 amp relay to turn them on automagically when I start the truck (and manually switched for when I’m parked). The wiring for the 2 compressors I am confident is accurate and adaquate. They draw 20a max I believe each. Also, would it be wise to add a 3rd 100A circuit breaker close to the positive terminal on the rear battery? Just in case of a short? I’m looking for opinions to make this better, safer, or if I just have something totally wrong. Engineers are encouraged to help! TIA
I specifically want to disconnect the rear battery from the main electrical system so that I am never stuck with a dead battery from my 12v toys. Thanks though.
Sorry but I’ve already decided against an isolator. From my readings it will create a .7 volt drain on the entire system. With a relay I just need to be sure I have 2 nearly identical batteries.
I still am forming a comprehensive parts list that I want to run by you pending the outcome of this thread. (also posted this on a few other sites) Do you stock these circuit breakers and spools of wire? Or is it something you’ll have to order if I were to buy from you?
the majority of what your looking for i have in stock, wire, connectors, and such, the circut breaker i may not, i usually keep 1 or 2 around but i sold out about a week ago. i get them in next day, i just need to know what size you need thats all, i usually stock the 100amp or 150amp.
I also carry the PAC 200 or PAC 80 relay/solonoid if you havent located those yet.
