hi
anyone knows how to install a Clutch??
i need one badly and i dont know how much i need to spend, i have an 92 240sx, the clutch is almost not drivable, doesnt grip at all, so anyone know how much to just get a replacement, and where to get them install it for cheap???
i dont know anything fancy, just a new one is fine, pls help
thx
Well you first have to find out why its not engaging first, reasons could be
Clutch Disk is worn out (most often the case)
Pressure Plate is fuged
Something is fuged with the slave cyl or the rest of the system
Clutch Disks are not to expensive at all for stock if its somthing else then the price goes up unless its just a bad slave then that is cheap. My advice is to get a friend to help you diy because labor for it will not be fun (better get ready to grab your ankles lol).
anyone knows where to get it done cheap???
my car has 320k on engine, if i spend $6-700 to get a new clutch and if my engine is dead then what can i do with the new clutch and a dead engine, so is there any better way or anyone know how to do it for cheap??
thxthx
umm, i dunno $60 for the clutch and p-plate. Clutch is practically brandnew, p-plate looks good but i dont know if the previous owner changed it with the clutch. or $40 for just the clutch.
i dont have time to install it, takes about 2-3hours depending on if things go your way.
Don’t get it done at the dealer…omg… My dad did the clutch on the celly at Toyota… 1300. Admittedly, they had to change the clutch, pressure plate and machine the flywheel… but STILL! 1300 bucks is quite the sum.
