I got a discount on a set of Coilovers for the Evo that were sent from KSport to be tested by vivid racing. After the test vivid racing said the camber plates rattle and should be redone, something neither me nor my friend has done. Does anyone have an idea and/or advice on how to do it?
Is it just the spherical bearing thats bad? If these plates are built in a similar way as my Ground Control units you can simply remove a snap ring and then press the old bearing out and new one in.
good luck with the ksports, i hear they always leak…
