Just Curious where to go? I plan to have it done below the body line on my zr2 blazer after i clean up some rust on. Thanks and preferably somewhere in the lockport/williamsville area within 20 minutes or so if possible since i plan to remove the bumpers and flares and have them spray those seperate as it is two tone.
What color? Don’t get white…it yellows.
are u talking about chip gaurd…?? in that case its a clear coat with a rough texture finish that gets sprayed on to the paint itself. The old clear coat also needs to be wet sanded down… maybe 6-800 grit sandpaper first.
no im talking about the spray on bedliner that they spray in the bed of trucks…and now they do a color match where they mix in the pigment from your paint code into it…and no it wont be white it will be the maroon/red with the bumper and flares being the spectra grey…just curious who does the color matched lining…
line-x… there is one on seneca st in buffalo
just a warning, its quite pricey. I looked into it for my ZR2 and it was quite a bit. They wouldnt even discount if i had 2 trucks done at once.
there is also one on Niagara Falls BLVD. 716-731-1133 give them a call. See what they say. Curious as to how expensive it is
I got a quote for my S-10 last year and it was over $600 bucks. If you dont mind DIY I have seen the color kits floating around under $200 on the internet.
dont they spray that shit on at like 400 degrees or something? and what color is your blazer? i wouldnt recommend the diy stuff, no warranty and the quality in materials prob isnt there.
try to get a discount if you prep it your self. i think they do it with 80
