NO PM`S, MY BOX IS FULL!!!
PLEASE CALL, TEXT OR EMAIL!!!
416.846.6754.
(you can email me clicking on my name and using the send email to ronnie tab)
Getting blowby in a my KA-T, haven’t checked compression yet. Don’t really care, going with a different motorset. Starting pissing oil out of my PCV into the catch can and through my intake today. No knocking or funny noises. No overheating, still drives fine, just blowby.
Drove it on the track for a few more sessions and then all the way home from Cayuga.
Im making these prices up so dont shoot me. I have no idea.
I will sell the COMPLETE SETUP with motor and trans and everything. This will include the exhaust as well. A literal BOLT on affair. You literally do not need to buy a damn thing. You can just transfer ALL of these parts into your existing KA right now. This is a BOLT ON 200-300 WHP depending on your tuning. The clutch is ready for mad power.
Without the Intercooler core for:
$2200.00
With the Intercooler core for:
$2700.00
1.) KA24DE w/65,000 KMS - haven’t checked comp yet but makes no funny noises or anything - $300.00
2.) Garrett GT3076R 0.60 A/R Dual Ball Bearing. Oil and Water Cooled Turbo - NO Shaft play. Looks almost brand new. Spools hard. - $950.00
3.) Apexi SAFC 2 - Perfect Condition. - $200.00
4.) NISMO Turbo Cams for a KA24DE (In. 248 / Exh. 248 ) - $350.00
5.) 370cc SR20DET Fuel Injectors - $100.00
6.) 475 Horsepower Garrett Core 24” x 6” 3.5” Front Mount Intercooler - Really short but fat core, should be able to keep rebar. May keep it if i don’t get what I want. - $350.00 core alone. $500.00 with piping and couplers for a KA24DE.
7.) Stainless Steel -4 Oil Feed Line, -10 Oil Return Bung and -10 Stainless Steel Oil Return Line with oil pan - $150.00
8.) Ceramic Coated Boost Designs Custom Stainless Steel Equal Length TOP MOUNT Turbo Header for a KA24DE. T3 Flange. $300.00
9.) Stone Racing Tial Style 38mm Sport Wastegate w/ 7psi spring. Piped into Downpipe. $150.00
10.) FULL TURBO BACK EXHAUST. Custom Metalex 3” Stainless Steel Down Pipe for top mount with a Custom 3” stainless steel mandrel bent exhaust with Magnaflow dual tip. Ralli-Tec Engineering Race Spec 3” Stainless Steal Core High Flow Cat. (System is made extremely well and sits as high up as possible for maximum ground clearance.) NO LEAKS! Beautiful system. - $400.00
11.) Custom 2.5” Stainless Steel Intercooler Piping Short Routed with Greddy Flange welded on to cold pipe - $200.00
12.) - Greddy Type R blow off valve with flange - $150.00
13.) Eurodrive Dual Diaphragm 2800lb Clutch with 4 Puck Kevlar Disc for KA. AWESOME clutch with tonnes of life and grab left. My fave clutch yet. -$300.00
14.) Custom 3” Short Ram w/ Blitz LM Intake Filter (6 inch diameter) - $100.00
15.) Greddy style oil catch can - $100.00
16.) - MSD 6A Multi Spark Discharge Ignition Module w/ Tachadapter + MSD 8207 Epoxy Core Blaster II Super Ignition Coil - $175.00
416.846.6754.
