i did a compression test on my KA24DE, and it did 230 across all four cylinder… is that normal??
^ I thought around 160psi is supposed to be normal? I could very well be wrong though.
i think you wanna be looking for 140-160
so whats with me getting 230 across!!!.. i found that kinda high
when you turn the motor open are you holding the throttle wide open?
i htink thats what you gotto do.
ya i did it with throttle wide open and got 230!!
WOW… boost the bitch and see what happenes… lol
BTW: check your tester… may be faulty.
what boost
LOL agreed!
Ka24de, 150psi minimum 200psi max.
well…low compresion makes for BAD turbo build, but the higher the pressure it holds the better… may not have stock internals and if it does then you got blessed… buy a T-25 and the mani and boost her to high hells
