daytime running lights
A shop did my daytime running lights by using single relay wired to ignition. he used the parking lights… It works fine but I noticed when the headlights are on…the engine wont turn off even removing the key from the ignition. the only way to turn off the engine is by turning off the switch for the headlights.
the shop gave up and cant correct the issue. Anyone has experience on U.S. model 2004 350Z
thanks…any help is appreciated.
