Hi, i am in the process of doing a redtop swap on my s14 kouki, it comes standard with abs, i will not be keeping the abs and there for the abs solenoid valves on the passenger side is just an eye sore so im going to remove it. I have stock brakes all around, the question is do i need a proportioning valve? What if i “t” the front line for the fronts, and a direct line for the rear. Do i need a different master cylinder? and where is the best location to put a proportioning valve, or would i be best off to keep the abs valves?
any help would be appreciated.
