So I have a Dell Optiplex SX270. It has an Intel Extreme Graphics 2 Controller with a DVI output.
So I bought a DVI-D Dual Link Splitter so that I could run dual monitors. The one monitor has a dual link DVI-D connector. The other has a Single Link DVI-D connector.
If I plug both into the splitter and reboot, I get the bios posts, I see the windows “I am booting up” screen(all of this cloned on both monitors), then it goes to nothing.
Also did this, windows up and running on the single DVI-D Dual link monitor. Unplug monitor, plug in splitter, plug in same DVI-D Dual linked monitor, I get nothing.
What gives? What am I doing wrong? I am under them impression that this card does allow 2 monitors because when I open the configuration software, it has the option but tells me to plug the monitor in first. Did I get the wrong Y cable?
Well if you are getting BIOS on both and then the Windows boot screen…it sounds like you just need to configure both monitors in the control panel under display/settings.
go into device manager. delete video adapter from the list and shutdown
Re-start with both monitors plugged in and see if that fixes it. it should automatically find the driver and re-install. If that doesn’t work, look around google for some kind of utility that does what you’re looking to do
