i have full Z32 TT rear spindles with the caliper / rotor / drum e-brake assembly and the e-brake cables from the drum assembly including the subframe mounts on the lines.
I do not want to clamp the S13 lines to the Z32 lines though… what is the standard install for this?
I was under the impression all you need is the center section that attaches to the ebrake handle itself from the Z32 in order to make the Z32 lines work as the S13 one is a different length.
i would also like to find out a definite answer from someone who has done the swap before, i just picked up Z32 rear hubs and brakes for my S13… don’t have any e-brake cables yet though… i’d like to know for sure before i get the wrong ones.
if you want the z32 e-brake cables that just bolt up to your S13, you need the 2+2 ones. They are roughly 49" long. The 2 seater z32 has shorter e-brake cables which are about 44".
The R33 cables are meant for S14’s.
