I got a few questions for those who actually have real experience. Does the Z32 TT ebrake cables work without any mods? Or does a custom bracket need to be made?
Are R32 ebrake cables the same deal? Just need a custom bracket to relocate the position of the cable?
I know there are write ups on import nut, but I don’t want to splice the ebrake cable or whatever.
Thanks!
PS: I want to use the R32 ebrake cables to save money, but if the length and lock up is shitty, I might as well order Z32 2+2 lines for the best lock up.
I used Z32TT cables with extensions off e-bay. Changed the crimps on the ends because I did not like the way they looked. Made two brackets in the driveshaft tunnel and two self tappers on each cable straight through the subframe. Works beautiful.
By no means is this brake set up good for locking wheels into a drift or anything like that. It is simply a parking brake. Works very very well for a drum/rotor system.
Also, as far as the e-brake cables goes, you can always fit the Z32 2+2 onto the S13. There’s not splicing/modifications needed for that to work. The Z32 Coupe ones are too short. The R32 e-brake cable might fit as well… but I’ve never seen anyone with it.
I used 2+2 cables on my s13. These cables are still a bit to short. But they do work fine and just require a slightly different route then stock. and a basic bracket to hold them in place.
