I don’t come on here often, but I have some decent E36 stuff laying around after the S54 Swap I did.
3:23 LSD 4 bolt output with standard E36 axle hubs. Great for 325,328 upgrade. $350
M3 sway bars $100
M3 steering rack $??
Bilstein shocks, Koni struts with eibach springs for E36 non M. Will fit M with shorter sway links $350
M52 engine that needs the exhaust studs drilled out. Mls high comp HG and S52 cams, pullies all installed. This was a strong motor before I swapped. $500
Dust shields $10
Aluminum thermostat housing $25
Parts are near Monroeville, PA, names Matt, 412 260 1397
