Soon it will be time to do something about the floaty feel of neglected suspension parts.
Planning to replace the following with some parts from a couple of M3s:
Front
Lower Control Arms ('95 M3)
Sway Bar & Links ('95 M3)
Struts & Upper Mounts ('95 M3)
Rear
Rear Shocks ('99 M3)
Rear Springs ('95 M3)
Sway Bar ('95 M3)
According to the below:
http://www.understeer.com/lcab.shtml
'95 M3 bushings offset CA location for additional caster (and high speed stability at the expense of low speed turning effort, is my understanding).
'95 M3 bushings are pretty sturdy
Now, the bushings in the lollipop bracket portion of the fronts do seem good, so I am inclined to leave these untouched (despite a lot of advice to the contrary I know).
But if I’m going to upgrade, then I may as well do bushings in the rear suspension as well right?
I’m thinking to buy the rear trailing arm (RTA) bushings:
Will getting the Upper/Lower RTA Ball Joint really do much? I was just thinking bushings but happened across this as well:
Do I need to do the upper and lower control arm on the rear suspension as well, where these mate to the subframe? See below
Questions & Stuff:
To reduce downtime, I was thinking to try and get a RTA as well as upper/lower control arms from another car and have new bushings put in along with ball joints then replace as a whole.
Is this a good approach? Can I use rear suspension components from any E36 (M or non-M?)
What’s labor cost on this? I don’t have access to a press.
Any recommendations for bushings? Powerflex?
Any suggestions on what do with in the front aside from possibly replacing the LCA bushing with a new one?
This is a daily driven car that I would just like to feel more planted and tighten things up. That’s all I need. Trying to avoid expenditure and a big science project, so I’m staying low budget where I can.
All advice is appreciated. Thanks.
