Here is the question- can you use a 5 speed sohc ECU in an automatic sohc car.
I know that the use of an auto ECU cuts the speed limiter in a 5 speed car but does anyone know what the issues are when you use a 5 speed ECU in an automatic. (I have been looking for a replacement sohc auto ECU for some time ) Any factual input is appreciated.
I’m pretty sure the auto computer has shift points programmed into it, if i had to wager i’d say it may work, but your engine light will probably come on and your tranny will shift like garbage, if atall.
Thanks for your input so far. I am trying this since the only SOHC auto ECU’s I have found have the same moisture damage as the original (usually causing 1 or more injectors to stop working) . As of yesterday I am using a stock SOHC 5 speed ECU and so far (30kms or so) all seems to work normally.
Has anyone else tried this ? BTW original auto ECU # 72 ,next auto ECU #13 and current ECU (removed from a 5 speed)#10
Now that I think about it, If you keep the auto tranny computer plugged in, it may still work decently. The ECU controls mainly the functions of the motor, the tranny computer will control shift points and such, of course these 2 do interact, so Im thinking there must be some point at which there will be a miscommunication between the 2. But for day to day, it should be fine…
