I got rid of the egr compleatly and put everything back together. But I can’t seem to figure out where the line from the fuel pressure regulator goes. There is a little pipe, beside the brake booster line on the air intake manifold, but if I put the hose to that the car idles really high for a few seconds then falls down and stalls. If I take it off and plug that hole and let the fuel regulator not attached to anything the car runs but it boggs down and runs really ruff. Mind you it seems much faster :). So where does this line from the fpr go to? Or what have I done wrong. A picture of where you guys put the line would be much appreciated thanks.
So, car is fixed, I tore the intake mani apart again and realized I did a shyt job at air locking the main egr piece that goes into the back of the mani, so if this happens to any one else make sure it is tight all around. Good day.
p.s the line goes where i though it did near the brake booster, i was just confuzed cause it was driving so bad.
