I’m in the process of removing a similar pipe. The IAV/EGR pipe connecting from that unit on the strut tower to the 2-1 downpipe. It’s hard because the edge for the wrench is very slim, and its rotted to shit lol.
I can’t imagine the one on the 4-2 manifold being any better. But yes it runs from the exhaust manifold to somewhere behind the intake mani. Try and just heat it. WD it. w/e. And give it a go with a wrench.
See I totally would. But I plan on plugging that pipe properly with an oem nissan part. If you search it up like ‘240sx IAV plug’ you’ll find the plug should be on nico or something.
But this is of no concern to you matty since you are clearly trying to pass a legit e-test. Best of luck man.
Your lucky to have got that out, I spent probably close to a hole day trying to get mine out, tried everything. oxy-acytalyn, monkey wrench, vise grips, nut buster, nothing worked. ended up cutting it and putting one of those plugs osad mentioned in the header.
Glad they like it! I hope they found how to use the washer nozzles. I forgot to show them. I feel it was worth what they paid. And I now have a 2000 Subaru impreza coupe - Which will probably get a V. 4 STI swap sometime over the next few months.
i failed to take mine out while swapping the ka, even w/ torch
ended up cutting it off, plugged both side, got a aftermarket 3-way cat and passed e-test on a 1 week new engine…
