well, im thinking of picking up a pair of 10" fans from hybrid, and i had a thought. if i reverse the wiring can i get them to spin the opposite direction? so that i could put them on the front side of the radiator instead of the back? or would i have to try and remove the blades and flip them over?
Yes, the fans I quoted you are reversable. If you are planning of running them in front of the radiator they are a little less effecient since they are blocking the air that they are trying to push through the radiator. So I would suggest a 12" and a 10" in pushing mode.
thanks gary, i thought about that and how much more room it would give me, im going to look tomarrow to see if i can fit two fans in the front.
