So i have some electrical problems which need to be solved. Here are the problems and how i’ve tried to fix them:
Drove it for a day and a half off of my battery started and ran great, until the other day i went home, parked, turned the car off, ran into my house, came back out, (forgot to press the clutch in, but i don’t think this is the problem), and my car acted as if the battery was dead (pressed the brake pedal and the digital clock fades/disapears.) and to no avail, car would not start. I boosted the car and it ran to the end of the street and died again. i boosted it and drove it home, again it died. after that my fuel pump fuses kept dieing, so i replaced the fuses, fuel pump and alternator. I replaced the fuel pump relay and that made the fuel pump fuses to stop blowing every 20 minutes, but the car still does not stay running.
Today i went out, boosted it, it will idle by itself, and for a period of time, but will barely drive further then 50 feet without dieing/stalling, and it won’t start on it’s own power, and only will start if boosted. if i press the brake pedal after its started the car will start to drop rpm’s unless i add some gas, and the “Hicas” light flicks on for about a second then off.
The headlights don’t go up or down, or turn on either, so i’m going to look into that.
So iask why isn’t my car won’t start by itself (it will start sometimes even if the boosting car isn’t even turned on), why won’t it stay running, why won’t my headlights work, and how do i check if i have short?
Did you get a brand new alt? Or a rebuilt? I’ve had bad luck on other cars with rebuild alt’s, not charging / car dying (just my experiences). I’m guessing it might be that or possibly some grounding/shorting issues. Check your engine grounds and look at major wire junctions to see any bare wiring on the chassis. I’m pretty sure someone will have a better idea or has had this problem before…
Also you might want to charge your battery. You didn’t explicitly say that you fully charged it each time you tried to start, so that could be a reason why you keep having to boost it (read: dead battery=no starty). Going 50ft won’t charge the battery.
KA24De, I just replaced teh alternator with one i got officially tested outside of the car, the alternator/regulator is fine. The car ACTS as if its dead, i put a fully charged battery in and the little clock turns off and fuck up. but it only starts with a boost which i don’t understand, i’ve checked the wiring for the alt even with a voltmeter and i get more voltage. i can ev en disconnect the battery and the car stays running, so holding a charge isn’t the problem, the problem is the car is shorting or something?
