Exhaust gaskets and Flywheel resurface
Anyone know where I can pick up 3" exhaust gaskets from? I went to ctc but they only have the elbow to downpipe one, I need the two bolt ones. Also, can you guys suggest some machine shops in the GTA for resurfacing a flywheel.
Thanks
Performance improvements will have the gaskets, and I’ve always brought my flywheels to Etobicoke Engines, $50 and have never had an issue with the work, they usually have it done in an hour!
I had my flywheel done at Innov8 Custom Machining here in Brampton. Cheesy name, I know, but the guy was very helpful and did great work. He noticed, and took the extra time to do the stepped flywheel used in the SR20, hot tanked and packaged up, all while I waited. Would definately recommend.
P.I. can order the gasket from Vibrant if it’s not in stock. http://vibrantperformance.com/catalog/index.php?cPath=1022_1068_1126 If you need it ASAP you can check Master Performance on Kennedy or any exhaust shop for that matter.
Arite thanks guys. I’ll definitely check those places out
I use collins.
