i’m changing my clutch this weekend and i’m wondering if i need to get my flywheel resurfaced, my engine is apparently under 60,000kms so it can’t be that badly damaged and its not going to get worse over time unlike the clutch.
also if i should what places do that? and on a sat/sunday.
if you can see slight burns or discoloration on the contact surface then have it resurfaced. might aswell do it well you have everything apart anyway. it should only cost $70 to $90. im looking for a place to get mine done also.
im doing my clutch this weekend too. do you know what size torque wrenches are needed?
i don’t what size torque wrench beacuse i don’t understand how that would matter because there are adapters, but i do know the torque for the bolts. and as for the flywheel, i heard it was like $30 to get it re-surfaced, like rotors.
really? see i got my sources off the internet and realitly does like to kick my ass so i wouldn’t be surpried, as for bolt sizes, i dunno i have a complete set so not a probelm, but sorry i can’t help you out.
10 lbs? Alot, theres a formula somwhere, i can’t remember what it was. But less rotational mass will make the car rev faster and you will gain hp, because there is less weight to spin.
